Davids Pipistrel Build Website
Date:  12-27-2016
Number of Hours:  0.50
Brief Description:  Cut out hole in cowl for gascolator
Mounted lower cowl, marked location for gascolator and removed cowl, drilled 1" hole at mark, cut back internal foil/insulation on inside of cowl about an 1/16 of an inch using a razor blade, sanded the hole to smooth it and remove the sharp edges (keeps gelcoat from chipping
