Davids Pipistrel Build Website
Date:  3-20-2016
Number of Hours:  1.00
Brief Description:  Siliconed the right wing tip strobe lens cover on
Drilled our holes in lens cover to fit my special stainless counter sink washers to hold lens cover on. Put a 1/8-3/16" bead of silicon around edge of lens pocket on wing. Laid stainless steel washers on the silicon to prevent screws from squeezing all of the silicone out and keeps the lens flush with the surface of the wing. Spread lens cover apart and placed it in pocket. Used brass wood screws through CSK washer to attach lens cover to wing (brass looks good with SS and won't rust)
