Brief Description: Ground base of wings and drilled drain holes
Previously marked base of wings with masking tape to provide a 2mm gap from fuselage when wings were mounted. Used dremel and sanding block to sand up to the edge of the tape. I had to be careful at the spars not to cut into the spars. Used rotory grinding wheel to remove extra epoxy that briged between the wing skin and the spar again being careful not to cut into the spar. Drilled 5mm drain holes in the wing and drill an 8mm hole for latch that holds the doors open
