Brief Description: Finished triming the wing roots
Tried power sander but it was too hard to control so switched to Dremel with cutting wheel. This worked much better. Sanded by hand to the line and then ground out epoxy between the spar and the skin using a diamond rotary cutter being careful not to cut into the spar
