Davids Pipistrel Build Website
Date:  8-23-2015
Number of Hours:  1.00
Brief Description:  Mounted Radiator
Measured and drilled holes in firewall for radiator (need to attach mounting bolts before I can mount firewall insulation/upholstery). Mounted upper radiator bracket on firewall. I will leave the lower bracket off until I am ready to mount the engine (don't want to bend them). I will have to cut holes in the insulation/upholstery to tighten but these holes will be behind the engine electronics board
