Davids Pipistrel Build Website
Date:  7-19-2015
Number of Hours:  4.00
Brief Description:  fitted and mounted the elevator
Had to install elevator hinge pins and then test fit elevator. More grinding on the rear vertical stab rib so the elevator control horn would not bind. Also had to sand vertical stab so that elevator did not contact it in full down position. Fit elevator control horn and drilled bolt hole for the mounting the control horn hinge. Removed horizontal stab/elevator wrapped it back up and put it back in storage.
