Brief Description: Instrument Panel Access Door Mod.
Started working on forward aft baggage bulkhead (F866B-1). Will be cutting a hole in bulkhead and installing a hinged access door to allow working on the forward portion of the instrument panel. This has been a common and popular modification RV-8 builders have elected to do. First step after alot of study on drawings is to cut out the opening. I reduced the opening size just a bit on the top portion, so as to not disrupt the angle braces that rivet to the forward upper F866B-1 panel.
