Terry Wighs
Date:  1-28-2009
Brief Description:  Right Fuel Tank Leak Testing/Manometer Method
27 inches of supported fluid column is equal to one PSI. After putting air into tank with air compressor through a fitting that is temporarily installed in the fuel drain fitting the tank was left for three days. Then I rechecked fluid level at the same ambient temperature (64 degrees in the shop) to insure no loss in pressure. I also sponged on soapy water over all rivets and seams to insure no bubble formation. Tank is leak-proof.
Water mixed with green food coloring and Marked at start
Tube of water comes out of vent then goes down then up vertically
Tank set up. Front fuel intake is capped off.
