Worked on balancing left and right counterbalance lead wts. Balanced them as a unit rather than seperate. Fabricated a drill bushing to drill the elevator horns. Final adjustments to rod end bearings for alignment of elevators with horizontal stabilizer with out binding. Rod end bearings torqued and torque seal applied. Final balance to be completed after painting.
