Terry Wighs
Date:  1-19-2010
Brief Description:  Mid-Fuselage F-823-1 Skins
Fabricated a 24 inch long 2" X 4" and cut 45 degree bevel along length. Cut and fabricated two 3/4 inch angles. These are needed to "ROLL" the lower aft mid-fuselage skin corners. I stressed on this step a few hours while cutting the wood, and thinking about it too much. The real key was "setting up" properly....taking my time and it turned out to be a "cake-walk". I am slowly learning that the preparation and "Firmly securing" the work is the most important step in most of the tasks to building.
Measure, clamp wooden beveled block and angles
Rotate and roll from angle
Finished rolled skin
