Terry Wighs
RV-8
Installed Left Fuel Tank Sender
Also riveted some aluminum/proseal patches on tooling holes in fuel tank rib. Float was tested with an Ohm meter. Deflection of float indicates a required range of 33ohms.....to 254ohms.
Fuel sender inside orientation on baffle
Fuel sender outside orientation on baffle
RV-8 Home
1215
252
474
Instrument Panel
Tools/Shop
Wing Craddle
429
