Brief Description: Mount Left Wing to Wing stand/plumb/level
I used two plumb bobs hanging from the flush bottom surface of the main spar.....and measured the distance from the rear spar flange to each string....then clamped in place with the Clamp....Also supported the mid rear spar with a jack to take out sag. I passed fishing line on the rear spar bottom surface....clecoed the string on each end in the 3/32 holes....then verified the string interseccted the holes throughout the entire length.
