Fabricated from 2 X 8 planks. I used piano hinges rather than door hinges. They were actually cheaper, and it seems to provide smooth operation. I took the boards after cutting to size to the local Vo-tech. carpentry department and had them put them through a planer to get very accurate working surfaces. Probably overkill on that. The handle came off of a boat that I had built back in the 80's. The boat has since deteriorated and left me a few parts. Nothing like a new tool, with a little bit of old history with it...:)
