Terry Wighs
Date:  10-15-2006
Number of Hours:  20.00
Brief Description:  Empennage fiberglass tips
The past few months have been a blurr, and not very well documented regarding work logs. Most of the work was bits and pieces of sanding/fitting/putty work, that seemed to go on forever.The hours are as accurate as they can be considering the work done. I also have been playing with Nuvite polish on some of the skin to determine if I want much of the plane polished rather than painted completely. I have deceided that I really like the polished look in spite of its labor intense aspect. I have also begun to design and think about a paint booth. I will be painting tips of the empennage/cowl/fuselage with a two color paint scheme as highlight paint only with the polished aluminum look as the primary appearance.
Horizontal stabilizer tip/plug
Rudder tip
Rudder tip
