Worked on the Aileron and Flap braces, Primed the mating surfaces. I have choosen to use AKZO primer on all aluminum surfaces that have a contact area which may trap water between surfaces. My hope is this will reduce the chance of corrosion. As you can see I alodined all the components but AKZO primed the contact surfaces.
