Preping the aileron brackets and braces, Needed to machine counter sink the two lower rivets in the brackets. Should have done this prior to making the brackets. I used a die grinder to hold the counter sink. It worked well. All brackets are matched drilled to the rear spars and the braces are ready to drill on the left wing.
