Dharma helped me set the joint rivets on the top right skin. These rivets were set with her backing up the rivet inside the wing and I was using the gun on the top side. The results were perfectly set rivets. Looking at the picture you can see the right rivets were set with the off set rivet set and the left ones were set with the bucking bar. Big difference.
