Begin the fabrication of the mounting brackets from the z material provided. marked and drilled the center hole for all brackets. Using a #12 drill. Debured and mounted on the spar for match drilling for the outside holes. Match drilled all holes, deburred ready for alodien and nut plate fitting.
