Installation of the inboard fuel tank rib. Installed all the fuel fittings, vent line, and fuel sender wire connections. Fuel screen retainer and stiffener ring. Tank mounting bracket and stiffner. This process is the messiest and most difficult job on the tank, Every fitting needs to be sealed and tightened to the final position. I went through 5 or 6 pairs of nitrel gloves. Everything is in and sealed. Testing of the tank will be the only real test of the tank.
