This is the best way I've found to clean the rivet holes in the skin. Using a power screw driver (mine is a black and decker low cost driver) and a philips screw driver bit. Place the scotch brite pad over the hole and then place the bit in the hole with the scotch brite and spin the driver. clean hole and very quickly done.
