Cut the vent tube for the right tank, installed the vent line bushings. Began the final components prior to the closing of the tank. Everything looks like its been made and deburred. Received the proseal on Monday. All stiffiners are ready for installation. I will start the sealing process by first installing the stiffiners then the filler neck, drain valve bung and the extended tank bung. That should conclude the first session of sealing.
