Continued the process of pitching and cleaning the shop. Total time today about 2.5 hours. I worked in the S/E corner under the large table and removed all the crap under it. Most of it I have not seen for many years. I tossed most of it. I found 3/4 gallon of muratic acid for what reason I do not remember and two gallons of used paint thinner I think I used to for cleaning the rotary engine, which I will not use in this plane. Anyway I move some long steel and aluminum pieces into the attic space. Preliminarily I laid out the location of the fixture and it will be tight with the big table remaining in the shop. I have no place to put it so I'll have to make due. I also went to Home Depot today and priced the lumber to construct the fuselage fixture. Roughly about $65 should do it. Wish I had a place to put the wings to give more area in the shop.
