Installed the left landing gear weldment. Had some fitment issues with the weldment and the stucture. Needed to remove a little material where the gear exits the fuselage. Still struggled with getting the weldment to set against the F804. Then I relized a plate nut was blocking the weldment. I made a slight grind onthe upper edge of the weldment and it fell right in.
