Worked on the parking brake valve installation. I've hit on the idea that I can use a pull cable to close the valve and a spring on the valve to open the valve. This would allow a light cable to be used as a pull cable which will allow a tighter radius. This tight radius will allow the cable to be located on the left side of the cockpit. I also primed all the small components like the baggage floor and angles, rudder angles and the F854 gussets.
