Drilled the new F812B bracket and found the holes I made in the bracket will be too close to the inside edge of the F887, so I need to make another F812. Third time is the charm. Decided to mark the F887 longerons at F812 for the 3/16" holes and drill them first and back drill the F819 and untimaltly the F812B bracket. This will make the edge distances appropreate. I took down the F825 turtle deck and temp installed it to see if everything is lining up. Also installed F810A top bulk head and everything looks good. The flanges on the F807, F808, F809 and F810A bulk heads will need to be fine tuned but that was to be expected.
