Brief Description: Final Riveting Turn Fuselage over
Jim and I finished the riveting prior to turning the fuselage over. This included installing the new F801Y gussets and new F801H angles on the firewall. Checked over the rivets and reset the few that needed to be done on the right side. Riveted the T bracket on the F802 bulk heads. Riveted the WD801 motor mount to F891R skin. Checked over everything. Installed the F801V crossmember. Removed all clamps and attach points. Had to cut the fixture at the firewall to facilitate the fuselage removal and turn over. Freed the fuslage and moved it outside the garage. We removed the fixture cleaned the garage and moved the fuselage back in the garage rightside up. Big Day Mile stone looking more and more like an airplane. Now to start the installation of cabin tail etc...
