After looking at the new drawings for the match drilled fuselage. I notice two gussets installed F801Y and F801W along the mid angle so I've drilled out the verticals and created the four gussets to install. I plan on installing The F801Y's inside two gussets prior to turning the fuselage over. I'm creating two X supports I plan on clamping to the F887 between F804 and F807 to stiffen the structure to minimize racking. I may make one to install between F807 and F808 also.
