Riveted the F804H stiffner to the Mid and forward cabin skins. Removed the skins and found I need to dimple the two AN426-3 rivets at the rear spar location. Compressor is down due to leaking check valve. Will repair and finish the dimpling of the frame. I can then rivet the mid cabin side skins permenantly in place and move to the F890 forward floor.
