Installing and preparing the forward skins for final asymbly. I've decided I want solid rivets at the F891, F804H and F823/F824 junction. To do this I will need to install with clecos both skins and make everything line up with the frame putting clecos in every hole. Then rivet the line common to all three parts, Forward skin (F891) spar support (F804H) and Mid Skin (F823. Then tape with duct tape along the F887 main spar at the mid cabin area and title the skins away from the frame. Then use a rivet sqezer to install the rivets along both sides of the wing spar. The first Two from the bottom will be AN426-4 with the factory head closest to the spar for clearance. Then AN470-4's for the remaining rivets. Hope this works.
