Installed the plate nuts on the left side forward F804 bracket for the floor. Had to remake the shim for the right side because I counter sunk the wrong side of the shim. Installed the left mid skin and forward skin for final check and fit prior to final installation. found one hole not drilled at the F889 longeron to F804 bulk head connection. Drilled I'll need to remove skins and counter sink hole. I'll be able to permenantly install the left skins soon.
