Worked on the right cabin side skin, debured and dimpled structure. still need to dimple the skin. Drilled the right arm rests to the F805 bulk heads. Dimpled armrests and bulk heads. Need to make some adjustments to the flange which lies under the belly skin so it will lay flat.
