Continued prep on Belly skin, debured the entire skin. Reinstalled on the skeleton and worked on the stiffner brackets and stiffners. Drilled the F808 bracket to the stiffner and the bulk head. Looks great and very the belly skin is very stiff. This has taken care of any oil canning in the belly and added stability for the transponder antenna. I still need to spacer the bulk head flange as there is a little depressions when the clecos are installed through the skin into the bulkhead.
