Continued the construction and installation of brackets for the stiffners on the bottom skin. I finished the construction of the brackets and drilled the holes for mounting. I need to place the tail skin under the belly skin so the final position will be correct then I can drill the brackets to the stiffner. I can then take everything apart and debur and dimple all the components. I should be able to start riveting the skins on very soon.
