Drilled the stiffner from F809 to F808. I used a 3/4"X1" .032" 2024 T3. it really provided the extra stiffning for the belly skin between the two bulk heads. I don't know if this position of the transponder antenna will be a problem. I'll see later when we get it flying. I drilled the mounting holes for the antenna and I hope all the nuts and BNC connector will clear. I'll buy the 90 degree connector tomorrow and see what I'll need to change to make it all fit.
