Brief Description: Support for Transponder antenna
Strated to fabricate the support for the transponder antenaa. I plan on using the Dynon transponder and it is a remote type so I can install in the rear of the aircraft. So i've chossen to mount it under the baggage compartment with the battery and the antenna will be installed in the next bay aft. Between F809 and F808. This installation will provide a stiffner for this area as well and reduce the oil canning that is typical of this span.
