Brief Description: right side fuselage and left F898
Finished the aux longeron and F895 with spacer on the right side of the fuselage. Started the process on the left side. I made two spacers and this side is going together much quicker, it makes a big difference when you've already done the sequence once. I've already bent and drilled and fitted the aux longeron and f895 with spacer. I need to take it down and debur then reinstall to continue.
