Completed the alumi prep and alodine of all the bulkheads and floor components. I will prime the mating surfaces so I can start riveting the components together. The tempurature of the shop is a problem. I've heated the alodine to over 85 degrees but the alumi prep is stone cold and takes much longer to work. If I were to start the buiding process again I'd spend some time building tanks able to handle all the parts with heaters to keep everything warm. Then you could build a part and finish it right away at least up to the priming part.
