Continued work on the floor ribs, drilled F-815 A & B to F-806 Bulkhead. Now all the ribs are drilled and fit perfectly to the bulkhead. I still need to drill F-814A, F-814EPP and F-804D angle bracket. I have a few more small part to make and then I can prep and alodine all the bulkheads and parts to begin the riveting process. I continued work on the driling of F-804B to F-814A, F-814EPP and F-814C angle. Using the newly aquired wing nut clecos I was able to pull the Rib and the angle to a tight fit, less than .002" I'm very satisfied with the attachement point to the F-804 B bulkhead. I'm very close to finishing all the fitting and drilling of the floor components. Started the installation of the Aileron manual trim components.
