Continued work on the Frames and components for F 804 B. Drilled the bulk heads to the carry through and remade the shim for the left side seat angle. Cut the seat belt attach slot in the top and mounted the plate nuts. Riveted all the bulk heads to the F 804 B and set up to rivet F804 A. Should be done with this frame soon.
