This has been a long design and build just to check all the electrical circuts prior to the installation. This design has an amp meter to test individual circuts and multipul circuts so the wire and breaker size can be optimized for function and weight. Proably over kill and possible waste of time and resorces but I had a good time designing and building. I've already tested a landing light and the current is 6 amps. The initial draw is 9 amps but once heated up which is pretty much instintainous the current drops to 6.
