Worked on the right wing tip Strobe reflector plate. Counter sunk the #6 screws in the plate see image #2. Looks cleaner, The screws need to be longer, I'll see if Vans sells a longer 100 Deg #6 Stainless screw. Hooked up the strobe for the first time. Man is it bright, very blue light and so bright you can not look at the strobe, hurts the eyes. I turned off the shop lights and fired the strobe as this was happening. Dharma was in the house and could see the flashes from inside the house she said it looked like lightening.
