Worked on the right wing tip tonight. Drilled the holes for the reflector and strobe. Cut the opening for the nav and landing light. Installed the nut plates and temp mounted the nav light. Will work on the landing light mount tomorrow. This went so much faster then the left wing tip. I new exactly what I was going to do and all the pit falls from the first one. Just like the right wing has gone much easier then the left. Should take another hour and a half to finish the right wing. Since I screwed up the lens for the right tip. I have to wait for Vans to ship the replacement so I can make a new one. Very good night.
