Started making the components to make the Rotisserie. This will allow the turning of the Fuselage while components are being installed. Cut the stand offs which will attach at the motor mounts. The stand offs are cut from 1" diam solid aluminum stock. The cross arms will bolt through the stand off and into the motor mounts.
