Created the right wind tip Nav reflector. This is the first attemped at the Nav light refector. Overall it worked out well. The mounting screw on the top is slightly low which raised the relecfor up. So I need to make a change to the mounting hole position. I'm going to refine this process and install the strobe, landing light, and Nav and give it a test drive.
