Tom's Web Site
Date:  4-11-2009
Number of Hours:  5.00
Brief Description:  Elevators line up perfect, once horizontal stabili
This took me a while to figure out, but after convincing myself I had flipped right and left stabilizers,
tried it (irony is the hardware is so close, the stabilizer could fit, the then the elevators don't match. Well I had put the stabilizer strut and flying wires in place. Remove temporary, adjust stabilizer horizontal (i.e. adjustable hardware at the bottom)... boom, everything lines up. Sheesh my little convincing myself something wasn't right compounded the problem. Live and learn.
Flipped trim tab hardware around to offset the trim adjust to the right. 0.600" spacer and 1.720" spacer made up (lathe makes fast work) to keep trim horn in the correct place. 3/4" offset obtained.
Fitted up control cables. Took a while to find some AN115-21 hardware I stashed a few years back. Located them when I realized current ACS pricing was $10.75 each, and I paid $5.80 for them about three years ago. Ouch!
TIP of the day: If you haven't crimped nico press connectors in the last year, practice on some scrap cable first. :)
