Tom's Web Site
Bearhawk
Harbor Freight Beading Tool
I generally avoid Harbor Frieght Tools, but for $60 (on sale + discount) I couldn't pass up the beading tool.
The tooling out of the box doesn't work too well. Edges are left too sharp (more likely to slice aluminum sheet then run a bead in it.
Made up a simple mandrel (0.875") with a flat for the lathe. Mount the tooling, clean up the edge, polish up the surface.
Need to make up a 'gap plate' as the wheels will twist away from each other on heavier material.
I also need to make up a guide
O hours, as not directly building related to the plane.
Out of box
cleaning up dies
practice piece. Need a guide.
Bearhawk Home
422
Electrical System
Floobydust
288
Panel
Panel
Sport Air Workshop
Stewart Systems Work
workshop
