Tom's Web Site
Date:  11-21-2009
Number of Hours:  4.00
Brief Description:  Side Panel Bottom Panel
Side panel. bent about 1" on bottom. Fitted panel, trimmed about 1/4" at top.
Bottom Panel. Cut out around the shocks (will fit rubber gasket and second panel in that area). Bend is 20 degrees towards front, 15 degrees in the back. 0.032" 2024-T4 has quite a bit of spring back, place bend around 17 degrees which worked nicely on both.
Dashed lines on the bottom were 'ball park' that I use as guess to eyeball front to rear. Obviously not the actual bend line that was on the top of the panel.
Need to make a plate to cover shock openings with rubber to go around shocks.
Image 3 -- Bend matches nicely with side panel.
Side Panel trimmed and fitted
open around shocks
open around shocks
bend to match with side panel
