Tom's Web Site
Bearhawk
Fuel valve and gascolator location
Someone asked where I mounted the gascolator. It is between gear legs, when plane is sitting the gascolator drain is at the lowest location.
Image 1 -- top view
Image 2 -- underneath. Fuel lines not yet run from fuel valve (bottom outlet) back to the gascolator.
Image 3 -- with sheet metal, the gascolator clears. I need to replace the drain with a simple flush unit (hangs out too low!).
gascolator aft (under alum. panel)
gascolator - bottom of photo
Clearance for a belly skin
Bearhawk Home
422
Electrical System
Floobydust
288
Panel
Panel
Sport Air Workshop
Stewart Systems Work
workshop
