Tom's Web Site
Bearhawk
Cable Clearance for trim & elevator
Still wiped out from a flu bug. Zero progress for this week.
Bolted up cables. On the trim rods there are two spacer bushings, to keep it aligned.
Plenty of clearance between trim and elevator cables.
Trim push rod is straight, needs a gentle bend for clearance on up elevator & trim tab up.
trim yoke offset to left.
push rod needs to be bent to clear
Bearhawk Home
422
Electrical System
Floobydust
288
Panel
Panel
Sport Air Workshop
Stewart Systems Work
workshop
