Brief Description: Adding more plate nuts, redid front floor.
Used Russ Erb's method of a plate nut jig. Marked and drilled a piece of scrap 0.100" steel with the holes for the plate nut. Small AN3 hardware, so first hole. Cleco. Second hole. Drill bit (not enough room to get in a second cleco). Drill third hole. Couldn't measure any wear to the jig. Simple and easy. Thanks Russ!Front Floor. Decided "what the heck" and remade it. I had originally trimmed it too narrow, mistaking thinking I needed to keep clear of the lower tube for fabric. Two problems with that, one is no fabric interior by your feet. Second is lack of support on the sides gives a feeling a floor is moving away. Not comforting for a passanger!
